My warm up routine for my silvia has been the following:
1. lock in portafilter and turn machine on
2. when heater light goes off, pull a blank shot until the heater light goes on again
3. repeat
4. repeat again,
5. grind, distribute, tamp, pull a shot
This routine has required me to switch on the pump for a few seconds just before locking the portafilter with grounds in, to get rid of overheated water. I suppose in a similar manner to an HX. In other words, the water coming out of the brew path is quite hot after this procedure. I have not measured it -- this is based only on whether it is flash-boiling when it comes out.
For the past week or so this cooling flush has been unnecessary, at least not until the machine has been on for an hour or so. In addition, the espresso has tasted more sour than usual. Everything else has been the same as usual.
Could there be some reason it is taking longer to heat up than normal? I do a descale probably two-three times per year using vinegar. The last one was just a couple of weeks ago so it could be related.
