by mini on Sun May 16, 2010 10:36 pm
My first night of testing was brief, and I didn't make any careful observations, but I thought I would write down a couple of things of interest. I could only pull two shots because I didn't dare have more caffeine at 7:30 with work in the morning. I decided to test the two extremes for a comparison - full resistance and no resistance. I used the same coffee, dose, and grinder setting.
Since I was using a higher dose than I am used to, it was a little difficult to judge how my mod affected flow rate or channeling. Surprisingly to me, both shots flowed. When stopping by time, "with resistance" was about half an ounce shorter. I will certainly have to experiment a lot more to determine the affect on blonding and flow rate.
There were two things of interest in how the pump behaved, however. With full resistance, the pump started to sound a little funky. 50 Ohms appears to be right above the threshold of very erratic pump behavior. My boiler kicked in during the shot, and I really noticed the lack of power. The flow seemed to throb a little bit, and the pump was super quiet. This is clearly not a pressure that I want to pull a whole shot at, although the ramp up to peak (reduced) pressure seemed more gradual than usual.
The second thing of note was that at "no" resistance, the pump didn't act completely normally either. It's possible that the pump needed re-priming after the resistance shot (maybe I inadvertently stalled it). It's also possible that there is resistance in my unsoldered connections, as I was previously advised against. I think the second is the case. When I first tested out my mod, it was after freshly assembling. I think that after a week of sitting, some oxidation has built up or the connections are now loose. I am definitely going to solder my connections soon.
Also, I bought some wire from Ira, and it is vastly superior to what I am currently using. It is a lot more flexible and seems higher quality. I will be changing the wire I use soon as well. Wire is probably the least critical component to this mod - there are lots of different types of wire that would work - but I would recommend purchasing some from Ira at this point. I like it.
matt
