by randytsuch on Tue Dec 08, 2009 4:40 pm
I added a preheater to my Gaggia Classic, between the pump and the boiler, and it is not working as well as I expected.
The problem is that the OPV on a classic is bolted to the boiler, so the OPV is after the preheater, in my machine. I set the OPV to 9 bar, and when I pulled a shot, there was a steady stream of water coming out of the OPV. This was wasting a lot of the preheated water, so the change in temp, measured with an over the lip thermocouple on top of the coffee, was about 3F during a 25 sec shot. I was hoping for better. And, it is dumping hot water into the cold water storage tank, which is probably not good, long term, for my pump.
DanB from the Gaggia forum suggested I add a resistor, to lower the output of my pump, so it would output 9 bar, and then the preheated water would not go back into the cold water tank.
I ended up adding a lamp dimmer on the pump voltage. I just did it last night, and it seems to work. I used my portafilter pressure gauge to check it out, and I was able to vary the pressure with the dimmer. I set my OPV to around 11 bar, and then set the dimmer to get a pump pressure of 9 bar. Now, at 9 bar, no water is coming out of the OPV.
There is a problem with this setup. When the heater turns on, the pump pressure drops, by a couple tenths of a bar. I have a PID controlling temp, and after the machine has stabilized, it comes on for a second, once every few seconds. I am planning to add a relay, in series with the control lines of the SSR controlling the heater. The relay will open the + control line when the pump is on, and leave it connected when the pump is off. I might also add a three way switch into the mix, so I have manual control too. Switch connections would be relay, open (off) and PID.
I was also thinking I could use the dimmer to do a crude version of pre infusion, start the shot with the dimmer set to low for some number of seconds, then turn off the pump completely for a few seconds, then set it to 9 bar for the remainder of the shot. Could even ramp pressure down at the end of the shot.
Installation is pretty straightforward. Dimmer is added, in series, to the wire that goes from the pump switch to the pump. Physically, I installed the dimmer on the rear side of my machine, behind the pump. I did have to remove the plastic body from the dimmer, so it would fit. I also had to cut down the mounting plate about ¾". I wrapped the dimmer with kapton tape, so it won't short anything out.
The shot I pulled this morning was a little slow, I have not really dialed in my Classic yet, need to do a little more tweaking of the grinds. I am also looking at adding a permanent pressure gauge, on the side of the classic. Since I can easily control the pump pressure now, it would be nice to monitor the pressure real time.
Couple other notes.
I have an old classic, it does not use the same Ulka pump they use now, it's an old, obsolete pump from a different manufacturer. Not sure how the current model pump will work with dimmer control.
My house voltage is a little high, I think around 120 or 121, which would contribute to a high pump pressure output, before adding dimmer control.
Randy
