The Vibiemme DD version 3 with PID control on the brew boiler has been out for some months now, but there's nothing I can find on users experience with temperature control, hence this new topic. I've had my DD now for a bit over 2 weeks now, so I'm still working out the kinks. For a great introduction to the machine and a detailed first look check out
http://www.espressomyespresso.com/. In a follow-up article I'll discuss my fun with adjusting the P, I, and D of the PID, but here I want to relate my experience with the temperature offset, also a feature of the PID.
The stock setting of the temperature offset is 19F, which means that the boiler will be 19 degrees Fahrenheit hotter than the water entering the basket. My wife and I have been drinking three different beans lately, Blue Bottle Roman that likes 184F, George Howell Matalapa that likes 195F, and Blue Bottle Retrofit that prefers 200-202F, so I've been all over the temperature spectrum. To measure temperature during the shot I drape a very fine gauge thermocouple over the 15-g basket and bend the wire it so that it is above the puck. I do notice that measuring this way produces a 2-5F droop during the shot. I attribute this to coffee swelling over the TC tip for two reasons: When I start with the tip under the coffee it reads lower than is usual, and when I measure the shot temperature without coffee but with a poor-man's Scace TC it starts at the same value and never droops more than 1F. I use these non-drooping values for the offset measurements quoted below.
Just a few words on the poor-man's Scace TC so you know how these measurements were made. Turns out that a hole in a blind back-flush basket 0.008" in diameter allows flow of about 2oz in 30 seconds with a pump pressure of 8-9 bar, just like a typical shot. So the same TC over the edge of this basket measures the temperature of the water in the basket.
So, on to the offset measurements. Unfortunately, the offset differs with set temperature and with whether the steam boiler is on or off. Surprisingly, the offset decreases (the water delivered to the basket is hotter!) with the steam boiler OFF. I don't have any hypotheses why this would be. All measurements were made after at least 45 min to stabilize and then after a 2-oz. flush. Here are the results:
Set Temperature(F), Delta-T(F) with Steam Boiler on/off
185 25/23
195 30/27
200 31/28
The fact that Delta-T increases with increasing boiler temperature is not surprising, since the heat loss from the exposed E61 group head increases. And knowing these variations it's easy enough to choose the set point to account for them. What I do find surprising, in addition to the behavior with the steam boiler, is that these offsets are all significantly larger than the factory value of 19F.
I hope these values will be useful to users of the VBM DD version 3. I look forward to measurements from others that can verify or improve on them. For the purist, room temperature was about 73F.
Gerry
