by HB on Sat Nov 26, 2011 9:05 pm
It's not how many cups per day that matters, it's how many times the pressurestat cycles, which it does anytime the machine is on. Eight months for a pressurestat is 2-3x less than I'd expect, even if you ran it 24/7. Since you're using 240V, the amperage switched by the pressurestat should be low (less than half that of the same wattage heating element as the US models). The Sirai pressurestats are commercial grade and should last many years, though given the light load, I would expect a Parker/MATER/CEME to be more than sufficient. It's weird that yours fried so quickly...
