Vibiemme Domobar Super - Control box, not working? - Page 2
Postby KSinning on Mon Jan 02, 2012 10:00 am
Maybe I wasn't clear - on "on" (I) with water in, all the lights are off - and the pump isn't starting, but if I lift the water tank the low water level indicator turns on - as it is supposed to do, but still no water in the boiler.
The US and European model looks the same to me.
KSinning
Postby erics on Mon Jan 02, 2012 10:31 am
Then, from what you are describing, the water level switch is at fault. You can TEMPORARILY test this by simply connecting the two black wires with a homemade jumper consisting of a 3" length of wire and two male spade connectors.
Ensure that the boiler has a proper water level by physically checking same.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby cafeIKE on Mon Jan 02, 2012 1:52 pm
Water level switch bypass tester
cafeIKE
Postby erics on Mon Jan 02, 2012 2:04 pm
Thanks Ian - perfect pic.
Skål,
Eric S.
erics
Postby KSinning on Mon Jan 02, 2012 5:04 pm
I tried that and it worked perfect, thanks a million - it is now up and running.
Is it possible to fix the switch or do I need a new one?
After refitting everything I want to make sure that all the seals are tight and perfect is it possible to make a pressure test or is it ok, if there is no visual leaks.
I also did have a technician to test the control box and there was no errors at all - Eric you got a lot of credits for your electrical diagram. Thanks again.
KSinning
Postby cafeIKE on Mon Jan 02, 2012 5:22 pm
Replace the switch
cafeIKE
Postby cannonfodder on Tue Jan 03, 2012 12:10 am
The switch is inexpensive. It is a SPST NC (single pole single throw normally closed) and should be available from you local espresso parts dealer for just a few dollars. You can run the machine with the jumper for now but if you run the reservoir empty it can cause some serious issues.
cannonfodder
Postby Randy G. on Tue Jan 03, 2012 1:47 am
Since that switch carries the entire electrical load of the machine, be sure to get one with a sufficient rating.
It's $30 + shipping HERE
Espresso! My Espresso!
Randy G.
Postby KSinning on Tue Jan 03, 2012 9:31 am
I managed to clean the connections of the microswitch - so now it's working until i get a new one. Thanks for the link.
KSinning
Previous
Return to Espresso Machines
