Well, it started with the pump running too long, intermittently. At the same time, the pressure wasn't dumping when the lever was lowered at the end of an extraction.
I've been trawling through the great information on this site, and so far have:
-disassembled and de-scaled the group head (very cruddy). Now re-assembled, seems to work fine....
-removed the water level probe, cleaned, replaced, tested. Needs replacing, but works.
-disassembled and de-scaled the OPV, all freed up (again, very cruddy).
-disassembled and de-scaled the Parker solenoid and its associated connections (Part 22 & 23 here:
http://espressocare.com/images/Parts%20...awing3.jpgIt wasn't noticeably cruddy.
It's now worse. Pump runs continuously when switched to 1, the boiler is not filling at all. Water runs back into the feeder tank, pressure is developing as normal on the pump gauge, water will flow from the group head if the lever is raised. So I'm guessing the Parker solenoid? Any other suggestion, especially on how to diagnose the issue further will be very welcome. I think I can find a solenoid locally, but most other parts will have to come on a slow boat from New Zealand!
I'm off to bed as it's 1 a.m. here, but will be on deck again in about 5 hours....
