The sound I speak of is from the pump, or so I assume.
I dialed up the pressure to 9, but its still "off" from the way the machine's always operated previously.
Normal: Flip up the lever, water flows, pump makes lots of noise (thank you very much vibe-technology), and it gets a tad louder while the pressure builds. And it stays at that volume level until you stop the pull.
Now: Flip up the lever, water flows, seems normal until pressure starts to build. Then, instead of louder it gets quieter, and while it now ramps up to 9, it then starts to "surge", and goes down to 8ish, and flounders between 8-9, but is very, very quiet.
I hope that's enough info / good enough description. Its definitely not working correctly...
