When I first got the machine, the Fluid-o-Tech pump didn't work. I figure some scale jammed it up. I took it apart, did a visual inspection (nothing obvious), then reassembled it. It did have some scale build-up, but more on that later... After reassembling, it worked!
Next, after cleaning everything on the machine and replacing gaskets, I reassembled and tested it. Again, the pump didn't work
Did a good descaling of the boiler and HX (man these Olympia-made machines are a dream to descale); after dumping the water from the boiler, I was shocked at all the crap that came out.
Now is when I began to do some functionality tests, and that's when I noticed the pump output at the brew-group seemed lacking. I suspected scale lodged somewhere in the "food-chain". Took everything apart from the pump to the HX - all the way to the shower-screen. No obvious blockage. All back together, and the flow was still low (about an ounce of water from the group in about 20-30 seconds)
Out of curiosity, I tried to back-flush the group, and I could barely get the pump to choke... even after running for about 30 seconds.
Next, I disconnected the feed hose from the 3-way solenoid, and checked the output there. Still lower than I'd expect it to be. Moving closer to the pump, I disconnected a coupled-adapter that contains a check-valve, and still too low. Next up was another adapter, this one including what I'd call either a flow-restrictor, or pressure-regulator, and tested the output again. Bingo. Good flow, and when I tried to back-flush, the pump strained after just a few seconds. That sounds more like what I'd think it should be. Question is, do I need the insert that I removed? My guess is that it was there for a reason. I know the question will be if the espresso is any good, but I'd still like to get input from the espresso-brains here on HB. I don't have a means for testing the pressure at the group, but a test shot I pulled with a known grinder setting and my normal tamp pressure resulted in normal espresso output and decent crema.
Here's a picture of the insert I removed, and an indication of where I removed it from (shown by ballpoint pen head).
And on the subject of the pump, if I need to replace it for some reason, I've found a source for Fluid-o-Tech 1106 pump... but I've got to specify either NPT or gas fittings. My guess would be they're gas because there's no Teflon tape on any threads... any ideas?
Thanks for all your input on this. This machine restoration has been a great education... and I'm eager to get it back together and make some coffee.
