by vulches on Mon Oct 05, 2009 6:19 pm
Yesterday my Vetrano decided to stop refilling, although this was after being on for a couple of hours with no rise in grouphead temp where the temp probe is. I have had the temp problem happen before and is fixed by opening and closing the lever (vapor lock?). However, I haven't had a problem where the boiler would refuse to fill. I can run the pump fine and know that water is not being restricted in any way. I suppose scale might be a problem despite my water softening and filtering setup from Chris Coffee. I did notice that the vacuum breaker was spurting more than normal (I think) when I had opened the case yesterday and am wondering about an electrical short. However, everything seems to be working (the heating element sounds to be working when I turn the machine on - I've unplugged the wire for troubleshooting now). Any ideas on where to look next for autofill diagnostics? I'm not quite sure how to determine if it's the solenoid or something else that's the problem. I cleaned the electrical connection to the solenoid that looked to have been decently corroded, but still nothing to get the boiler to fill. I'm wondering if the problem is actually somewhere atop the boiler with one of the other electrical components that won't allow the signal to be sent to the fill solenoid. I looked for a similar problem in other posts but couldn't find anything to help me. So, I appreciate any insight that can be offered!!
