V vs S begins (Vesuvius vs Slayer) - Page 2
- Compass Coffee (original poster)
Interesting feature of the Slayer is there is no hard power switch and no electronic soft power off/standby/power save method. I couldn't find a way in the user guide so called this afternoon and confirmed I wasn't missing something. In other words there is NO way to turn off or manually put in power save mode. That said when (and only when) timer M-F and/or SS on/power save is setup if in power save mode and you wake it up (simply tap the paddle) will go back to sleep after 1/2 hour of inactivity. Must set schedule first or always stays fully on. And never fully turns off, always power save with reduce boiler temps 10 minutes or so to be back up ready. Unless unplug from the wall of course! I believe this is in keeping with Slayer's minimalist approach to what is arguably an advanced complex commercial class machine. At first thought it kind of nuts but have accepted their approach as acceptable and in keeping with staying away from when most major failures occur - during power on and heat up from cold.
Mike McGinness
- spressomon
Mike,
Relative to no on/off switch do you know if there would be any issue (Slayer side ) with using an on/off timer?
Thanks for the excellent 411...I've been on the fence about a new Slayer 1-group or Synesso 1-group...damn decision making anyway
No Espresso = Depresso
spressomon wrote:Mike,
Should be the same as unplugging, leaving unplugged for x time, plugging back in. The question becomes what state does an already setup Slayer return to when power applied. I cannot answer that at the moment because I haven't unplugged it since first plugging in Saturday. One would assume it would return to it's previously programmed state. But I assume nothing and will test and get back to you.
You are welcome. Different approaches to achieving similar if not the same excellent results. Flip a coin! I will say Synesso display much easier to see and not potentially blocked by cups. My decision was because currently leasing the house so outboard pump placement and especially 220v run was not realistic.Thanks for the excellent 411...I've been on the fence about a new Slayer 1-group or Synesso 1-group...damn decision making anyway
Mike McGinness
How's the slayer compared to the gs3 strada mod
Can you do a short like/dislike; can you do the long slayer style preinfusion on the moded gs3
Im new to this discussion but I currently have a single group slayer and recently had a GS/3 with strada mod. I could do a preinfusion as long and at as low pressure as the slayer....the slayer is easier to use, however
- shawndo
"easier" is an understatement. I could never get the same flowrate from the strada MP-type group 2 times in a row by eyeballing it.
I eventually just gave up on trying. It makes the idea of dialing in an espresso impossible for me.
It has the theoretical ability, but you need a nanometer-calibrated robot thumb to make it repeatable. At this point I think a flow-profiling mod would be better than a strada mod.
Darmok and Jalad at Tanagra
- BaristaBoy E61
What happens to a Slayer's programming if the power is completely interrupted, as when its breaker is turned 'OFF'?
Nothing bad. I unplug mine every time I take a trip which is frequent. Not sure what would happen if power were interrupted during a shot pull or something similar.
I find this interesting! Was the GS/3 strictly with the Strada mod or did you have a needle valve installed, as well? I thought it pre-infuses with like pressure (2-3 bar) compared with the slayer than can preinfuse with <1 bar if desired?Bob_M wrote:Im new to this discussion but I currently have a single group slayer and recently had a GS/3 with strada mod. I could do a preinfusion as long and at as low pressure as the slayer....the slayer is easier to use, however
Interesting to say the leastshawndo wrote:"easier" is an understatement. I could never get the same flowrate from the strada MP-type group 2 times in a row by eyeballing it.
I've never heard that comment about the gs3 strada mod, but wouldn't that also be the case with the non electronic paddle strada as well
