by normriff on Thu Feb 16, 2012 11:45 pm
awesome help.
I looked online and found the push!!! button...
It appears that the push button also can be turned... like a valve... I assume you can adjust the flow? If you turn it "clockwise - off" it comes to a stop.
Turning this shaft disassembles the valve and does not adjust the flow of water. Turn the shaft clockwise and then stop turning it.
Can i just pour preheated water + descaler in the unit and let it soak... and then just pour it out? and rinse a couple of times... or do I need to pull the heating element?
You can, but keep in mind this does nothing to treat the inside of the heat exchanger (the water inside the heat exchanger and boiler ARE separate and do not intermingle) Such a thing would be useful for removing a burnt milk residue but not a lime scale issue.
Also.. it has 2 drain lines underneath.. how much drain will come from these?...Can I put a collection jug under my unit...or is it gallons?
There should be two silicon lines going into the plastic drain cup. One is from the expansion valve the other from the cup tray. There is almost never a discharge from the cup tray. However WHEN the expansion valve goes bad, it can pass quite a bit of water, overflowing even a 5 gallon bucket overnight. A correctly adjusted expansion valve passes about one drop of water every 5 seconds. At least that's what the folks at Crossroads told me back in '89
Any other maintenance I need to do prior to putting it together, and giving it a 1st run?
I assume you did the PF seal and screen already? Took me three hours the first time I did one. Have fun with that. Backflush? Any leaks out of the steam or water valve? Expansion valve?
Good little machine. I installed a few of those.
Norm Riffle
The Original "It's A Grind", Portland Oregon - Espresso and Coffee Equipment Specialist since 1992
