by wookie on Sat Nov 13, 2010 3:25 pm
A flare fitting is a metal to metal seal of two precision surfaces. The nut just holds the two sealing surfaces together. So being loose or misaligned are likely causes. It's still good practice to confirm that the surfaces are smooth and appear to be aligned before tightening.
Do not over tighten. Tighter is not always better, it can damage the fittings. Just finger tight, then no more than half a turn more with a wrench. I'd try an eighth to a quarter turn to start with, then a bit more if needed until it seals. Also try to narrow down where it is leaking.. is it possible that it is leaking from the solder seam to the extreme left? Or is definitely coming from somewhere around the retaining nut?
