The boiler never stops filling.... I checked the spring loaded manual boiler fill lever valve and that's not leaking. I check the auto fill solenoid and manual shut off valve on that line and that's not leaking either. The only other line that is connected to the water fill and the boiler is the line that feeds the group head. After the pumps high pressure out the water line goes into and back out of the boiler as what appears to be a preheating loop before it goes to the group head.
Could it be a crack in the water jacket in the boiler? The green arrow is the in where the overfilling seems to be coming from; the red arrow is where it looks as it should continue on to the group head. Therefore, the only way the siteglass would continue to rise if the water was only entering the boiler from this pipe would mean the the HX in the boiler is cracked i suppose.... it's in such good clean shape I find it hard to believe... but it might be time to get out the brazing rods.
Any input would be great.
Thanks,
Chris
