Up close and personal with the Slayer! - Page 2
- JohnB.
From what I've read the GS3 uses a pump assisted pre infusion not line pressure. Below the Speedster price point the only machines offering line pressure P/I are the Vivaldi S1V2 & the Dalla Corte Super Mini.Psyd wrote: If I understand all this correctly:
The GS3 (and others) allows you to open up the valve and allow line pressure in, and at some point engage the pump at high pressure.
LMWDP 267
- Marshall
The GS/3 Paddle uses line pressure for preinfusion: https://www.coffeegeek.com/forums/espre ... nes/426628
Marshall
Los Angeles
Los Angeles
- JohnB.
So how does that work in pourover mode or is the paddle version strictly a plumb in?
LMWDP 267
All I can speak to is that the Slayer can set the pre-brew (and post brew trail) pressure anywhere from 0 bars to pump pressure, it is independent of line pressure (Slayer has been run from a sump bucket and performed beautifully). I wish I could offer more info about the other systems, but nobody will let me near their machines for comparison.
Dan
Dan
- Jepy
I'm still trying figure why they use a mechanical needle valve for the group instead of a normal 3 way .6mm gicleured down? If the over revved rotary is activated at the first movement of the paddle(stage 1 regulated to say 3 bars), then move a little more and full pressure regulated to say 9 bars starts, seems to me the regulators are switched between with standard 2 way solenoids.
At what point in this pressure curve do you have needle fine adjustment and control?
From what I've seen, it doesn't look that different from a standard Synesso with line pressure(the pre-infuse pressure) regulated. I wonder what they set that one rotary pump pressure at to compensate for three groups going at once, 12 bar, 15bar?
@brokemusician771 - Sounds like you had a great experience. I really need to try a shot from the Slayer.
- brokemusician77 (original poster)
Thanks. It was a great experience, although I'm looking at my little Gaggia now and.......
Also, I made a mistake in my initial post. It was Jason Prefontaine who I spent time with. I called him Dan.
"There's a fine line between hobby and mental illness." - Anon.
LMWDP #326
LMWDP #326
- networkcrasher
Not knowing Dan, but after e.mailing and meeting Jason at SCAA, he's a super nice guy. Very passionate about the Slayer, and rightly so.
Great machine, reeks of quality, and produced one of the best shots I've ever had. Twice.
I am trying to figure out why someone is referring to 2-way valves, mechanical needle valves to control the group and over-revved pumps? None of these are features of the slayer machine. Okay, we do use a 2 way valve to fill the steam boiler just like everyone else.
As for pump pressure, multiple group machines have been running on single pumps for decades without "over-revving" or dialing the pressure up to 12-15 bars.
Dan
Dan
