mrgnomer wrote:I've read too where preinfusion of an e61 with a rotary pump operates best at about 28 or so psi.
Unless you move the lever to the half position where the valve has opened but the pump hasn't engaged, it won't matter, since once the pump has started, it's providing 9 bar output in a flash. The E61's expansion chamber is what provides the preinfusion (the
patent explains how in gory detail). That said, I agree with you, there's certainly no harm in installing a pressure regulator, if only to assure a more constant inlet pressure. I regulate mine to ~25 PSI.
