burlsube wrote:My prep usually goes a little like this -
Grind fresh beans using Vario into portafilter (usually set to 13.4-13.6 seconds)\
Remove portafilter from grinder and gently tap on tamping stand
Level grinds using straight edge
Give a medium tamp
Tap portafilter with tamper
Tamp again
Wipe grinds from portafilter
I'll try rotating the basket and see what happens.
I think the consensus has been not to "tap" after tamping, no matter how little of a tamp it is. Try not to do it (It's hard to break that habit, I know, trust me) Also, if the shots taste good, everything is level, then give this a shot:
This is an adjustable spout, turn the screw and internally it will "tip" to one side or the other. I think this is typically used in commercial settings.
http://www.espressoparts.com/F_1706
