Uneven IMS 200IM shower screen
Hello everyone, I have an IMS200im shower screen on my Expobar E61 office lever HX, during these 2 weeks, I found the 'mouse tail' is on the right side instead of middle, this repeated absolutely same every day and every cup. I am sure I have no problem of my tamping technique, since I am using an OCD and a Fly-Tamper. Do I need to replace it ? Did anyone heard of this problem ?
I did take it down for cleaning and it looks normal, no broken
Are you sure it's not pushed in on one side? Reason saying I jammed coffee on my screen when first got it and it bent part of it in and pulls did the same thing, I removed and pushed out and fixed it. If not, maybe try turning the screen 180 degrees and see if the mouse tail moves with it. If it does, then definitely the screen. If not, then it's something else.
Thank you for your advice, I will try it today. You mean the ground coffee jammed into the edge of the shower screen ?
I mean it pushed up on the screen and part of it bent in (up?), but couldn't see it until I took it out. Did exactly what you experience, all water went to that side. I just pushed it out from the inside and works fine now. May not be, but rotating should give a clue I think.
I have turn the shower screen 180 degrees, then the mouse tail follows the shower screen. I have checked the shower screen and it has bended, but I have no way to fix it. Now I am using the original expobar one
