ULKA pump replacement
Postby JY on Tue Dec 06, 2011 5:14 pm
Would it be okay to replace an EX5 41w pump with a EAX5 52w?
-Jim
JY
Postby stefano65 on Tue Dec 06, 2011 5:36 pm
yes it will
most manufacturers now days do not use 41w anymore they all switched to 52w
Stefano Cremonesi
Stefano's Espresso Care
Repair & sales from Oregon.
stefano65
Postby compliance on Tue Dec 06, 2011 8:58 pm
I just did this on my Brewtus last weekend. It was a drop in replacement. No problems at all!
compliance
Postby JY on Tue Dec 06, 2011 9:39 pm
stefano65 wrote:yes it will
compliance wrote:I just did this on my Brewtus last weekend. It was a drop in replacement. No problems at all!
Good thing!
Thanks,
Jim
JY
Postby JY on Fri Dec 16, 2011 10:15 am
What's purpose does this fitting serve? I've got one on the end of the Ulka pump in the MiniGrimac.
Initially I thought it was a pressure limit, but I'm getting full pop from the pump after the fitting.
-Jim
JY
Postby civ on Fri Dec 16, 2011 11:04 am
Hello:
JY wrote:Initially I thought it was a pressure limit, but I'm getting full pop from the pump ...
I have never seen one of these but my take is that if it is on the business end of the pump and water goes through it, it can't be but a valve that will open when the pressure reaches a certain (fixed or adjustable) value. It does not seem to be an OVP as I see no overflow exit in the photo you posted.
Please look for a screw or bolt head inside or outside the valve body (the arrows in the photo indicate the possible locations) to regulate the spring inside the valve. If there is one, it will probably allow you to take it apart for cleaning and maintenance.
If you can disassemble it, try cleaning it in hot vinegar.
It's most probably stuck 'open' 100%, hence the full pop you describe.
Cheers,
CIV
civ
Postby JY on Fri Dec 16, 2011 4:11 pm
I found some info. It's a priming valve.
JY
Return to Espresso Machines
