Ulka EX5 pump replacement
Postby bryston on Thu Dec 08, 2011 10:19 pm
hi, am replacing my ulka pump on my giotto, the original pump is ULKA EX5, can I use ULKA EAX5 instead?
thanks
bryston
Postby HB on Thu Dec 08, 2011 10:41 pm
I knew the answer was yes, but wondered why. From the CEME website:
Evidently the EAX5 is another class of pump than the EX5, but it's of no consequence since the EX5's higher duty rating (2 minutes on/1 minute off) doesn't matter for espresso. The X means it has brass fittings (P = plastic).
Postby indend007 on Thu Dec 08, 2011 11:29 pm
What's your rated frequency in there??
Voltage, and Hz should be considered..
In here ROK(rated frequency 220V,60Hz), ULKA EX5(230V, 50Hz) doesn't work well(Can't make enough extraction pressure)
So, It changed to ULKA EAX5(220V, 60Hz). Now, pump works perfectly.
Most of all, check the rated frequency. And find suitable EAX5 model. That's all. :)
Korean HomeBarista unity! Cafe Espresso and Bottomless Boy!
indend007
Postby HB on Thu Dec 08, 2011 11:58 pm
Good point Devin! A good reference is Wikipedia's Table of mains voltages and frequencies by country.
Postby Carneiro on Fri Dec 09, 2011 5:42 pm
Strange that here we have 220V/60Hz too, and the Elektra Semi with the 230V/50Hz pump works fine. The max pressure is around 12-13 bar...
I have to compare both pumps (it's easy to find the 220V/60Hz here) some day.
Márcio.
Carneiro
Postby indend007 on Fri Dec 09, 2011 8:50 pm
Carneiro-
Yes, you right in certain case.
Here some test
Feed variable input voltage and Hz to 2 pumps.
With needle valve, extraction pressure was made at 9bar. And measured flow-rate.
EX5(AC230V/50Hz 9bar)
EAX5(AC220V/60Hz 9bar)
IMHO, in real world, there is some difference real voltage and rated voltage.
In some tests with two different Hz environment above, pumps are very sensitive with Voltage change.
Maybe ULKA EX5(230V, 50HZ) does work well in real voltage over 220v(60Hz).
But pumps show bad condition under 220v(e.g 210V).
indend007
Postby Carneiro on Fri Dec 09, 2011 8:59 pm
Very interesting!
Carneiro
Return to Espresso Machines
