I'm a first time poster - but have recently stumbled across your site, and have picked up some great tips on this website - so thanks very much for the helpful information.
I've been a long time La Pavoni Professional user, and recently converted to a Rancilio Silvia Machine.
I absolutely love it and can get pretty much great shots every time. I recently bought another Rancilio Silvia machine, so that I could have two - one at home and one at work.
Here's where the problem starts. Although I can get great coffee from my first Silvia, I cannot for the life of me get a good coffee out of the second Silvia.
Here are the different combinations I have tried and still can't get a sweet spot: (I've easily made over 70 coffees trying different combinations)
- Changing my grind (using a Macap commercial grinder) I've tried 4 different settings ranging from choking the machine, to pretty much a massive under extraction
- Changing my extraction time from between 20 to 30 seconds
- Changing the amount of coffee in the basket from between 12 -16 grams
- I always tamp at a consistent 15kg of pressure (measure using scales) - I haven't changed that
P.S. I'm temp surfing both machines
Here are the differences I've noticed with the machines:
-With my first Silvia the boiler shuts off after 55 seconds. The second one switches off after 40 seconds.
-The sweet spot on my first Silvia is 14 grams of coffee in the basket (for a double) and I get the best on the second machine at 13 grams (and still isn't very good.)
-The pump on the second machine is noisier.
-I did a very basic test of temperature on both machines, and the second Silvia looked to put out slightly colder water. Not much colder - but def colder.
I bought both machines second hand - but both are mint, and I know the sellers personally and they didn't use them much at all before I bought them.
The second machine was not used for a while and had water left sitting in it. I thoroughly descaled/backflushed it and water coming out is clear and doesn't have a bad taste. I maintain both machines meticulously.
The thing that is so annoying is that I consistently get great coffee from one machine and the other one is terrible. If I got served the coffee I make from the second Silvia at a café - I'd return it for another. It has that bad aftertaste, that stays in your mouth for a while after drinking it.
I was wondering if the fact that I need to use less coffee in the basket to get a satisfactory volume of extraction, and that the temperature is colder - that I need to increase the boiler temperature in the second Silvia. What do you guys think? Also - is that something I can safely do myself? Is there anything else you guys can recommend doing? Any help would greatly be appreciated.
Thansk Danny
