CoffeeOwl wrote:...And now all the dosing from 16 via 17, 18, 18.5, 19 up to the 21 g is available. That's what I wanted. Lack of this was the only flaw of the machine for me.
I fully agree with this.
woodchuck wrote:Similar experiences to many of the contributors here. I had an early triple from Lino. Blew thru a ton of coffee and finally decided I preferred the more subtle flavors from the double. I still pull it out once in awhile especially in the winter when I feel like a warm cup of hot cocoa
CoffeeOwl wrote:John, I don't agree with your theory on the basket geometry.
RapidCoffee wrote:Another thing to note: the 53mm Spaz double basket already has the geometry of a triple basket. If you really want a triple dose of coffee, you are probably better off with a 58mm E61 box.
RapidCoffee wrote:If you're referring to taste, I'm not going to argue with you. De gustibus non est disputandum.
But basket geometry is easily verified. The 53mm Spaz double basket is taller and narrower than its 58mm counterparts. For example, see the pic I posted here. There's also some interesting discussion about basket diameter and height:width ratio on that thread.
dialydose wrote:This still doesn't make sense. A triple is defined by dose, not geometry. The Spaz double basket is taller and narrower than a 58mm basket, yes. But "if you really want a triple dose of coffee" and you own a Spaz, then you should get a triple basket for the Spaz.
Dodger1 wrote:John was kind enough to sell me one of his Dalla Corte triple baskets. However, after using it for awhile I came to the conclusion that the stock double basket was all I needed. However, I know some of you are simply dying to get one, so I'll be posting my Dalla Corte triple, with a modified bottomless pf, over on the S1 Cafe Swap Board today.
RapidCoffee wrote:But basket geometry is easily verified. The 53mm Spaz double basket is taller and narrower than its 58mm counterparts. For example, see the pic I posted here.
