Hi guys,
I'm sort of in the middle of putting together a small espresso machine and it was suggested to me by a HB member (pdx) that it might be a good idea to get rid of the 3-way valve and add another tube from the group to create a 'exhaust' for the pressure purge after a finished shot. This does sound good, but I was curious if anyone ever used a machine like this? I was planning to use two 2-way solenoid valves instead of the 3-way valve, put one on the group supply line and one on the 'exhaust' line. The only problem, I see here is that the 2-way valve will have to be connected with a bit of tubing which might affect thermal stability. I was looking for something that looks like the 3-way (size-wise and how it fits under the group), only in 2-way version, but couldn't really find anything. A double 2-way interchanging valve might be a good idea, but I'm guessing they are a bit large and might not fit easily.
Btw anyone knows what non 3 way machines use to block the line between the boiler and the group? I'm guessing there's has to be something there otherwise when switched to steam-mode, water and steam would escape through the group.
Regards,
dsc.
