Jeff wrote:Some of the more sophisticated designs make sure that the PCB connections and the thermal sensor are, as much as possible, tied together thermally, often with a big block of aluminum (or copper, if you are feeling wealthy).
There is a provision in the TC4 design (not documented) that would allow you to do this. The idea would be to epoxy a brass (or copper, aluminum, etc.) bar to the backs of the green wiring terminals.
Instead of reflowing it to the main PCB, the MCP9800 then gets mounted on a small breakout board. There are already 4 extra vias added to the PCB for the flywires needed to connect to the breakout board.
The breakout board with the 9800 then gets epoxied to the back side of brass bar. This arrangement would provide a nice isothermal block for the cold junctions of the 4 thermocouples.
I haven't found this refinement to be necessary, though. Apparently the combination of a nearly solid copper ground plane on the back side of the TC4, plus the low mass of the green connectors, is enough to maintain a nearly constant (and small) offset between the junctions and the ambient temperature sensor.
Jim
