sheygetz wrote: So, there's actually two criteria. To put this differently:*How much does any given machine overheat with, say, 30 to 60 minutes between shots?
(Is that about right, guys?)
*How much of a temperature loss occurs while the shot's being pulled?
Actually there's a third; consistency shot after shot on repeated shots. That's where bigger is better. BTW, the Junior has an absolute monster combined heat exchanger/group that probably means more to its shot after shot stability than the boiler.
On the second criterion any machine with a heavy group is great. The E61s, the Junior do very well. Dual Boilers with heavy groups do even better.
On the first criterion, the dual boilers shine. Properly engineered like the current Synesso and the fresh off the line LMs, they do the same after idling or in heavy traffic. A well built home dual boiler like the Brewtus or S1 have a two C rise after the first shot (cold nose). If I had one, I'd set it so the first shot was the temp I wanted, reset it for company, and make the first (cold) shot a latte.
In terms of being able to make 3 or 4 shots in a row at wildly different temperatures, nothing works as well as an overheating E61. A few minutes wait, the right flush, and one has any shot temeprature from 100C to 85C. No waiting for the PID to redo the brew boiler. This is why I'm not switching machines. I freely admit not being able to taste a 0.1C or most of the time even a 1C temperature difference.
