Temperature Offset On New La Spaziale Vivaldi II - Page 2
Postby mgwolf on Fri Jul 04, 2008 9:55 pm
jmcphail wrote:I program that on the single-shot button. My double-shot button is programmed for a bit under 2 oz., and I get that amount with or without coffee in the basket.
That's interesting, because with no coffee in the PF, 4 oz comes out of mine and with coffee, about 2. Sometimes, if I grind too tight, I might only get 1-1.5 oz.
mgwolf
Postby jmcphail on Fri Jul 04, 2008 10:31 pm
My bad, I measured with two different receptacles!
I just ran another blank shot into the same graduated shot glass I measured the coffee shot in earlier and it measured closer to 3 oz., while the coffee shot measured a bit over 2 oz. including crema. It makes sense, the coffee is going to retain some water.
Interesting that your puck retains 2 oz. while mine holds @ 1/2 as much, are your pucks soggy or dry?
Now I have to figure out what exactly the 2 oz line on my measuring cup is!
jmcphail
Postby JohnB. on Fri Jul 04, 2008 10:57 pm
I fine that about 3oz or a little less is required for a typical double (16-18g). 4oz does sound a little high.
LMWDP 267
JohnB.
Postby woodchuck on Mon Jul 07, 2008 2:59 pm
Sorry I didn't jump in earlier but I have been in the field for the last week. I have my double button set up for two ounces (with a full pf and measured at the top of the crema). What I found worked best after a long idle period was to pull a double (empty pf), wait for the temp to come back up and pull a second, wait for the temp to come back up and pull the real shot ... Ian
woodchuck
Previous
Return to Espresso Machines
