treshell wrote:I just got a new temperature gun and of course am pointing it everywhere. The temperature of the water in the portafilter is 160, and 148 in the cup. That seems low?
An infrared thermometer is a poor choice for measuring this. An IR gun reads a surface temperature. The water is going to cool rapidly once it leaves the group head. We don't know what temperature your cup was preheated to. And then there is the fact that common models of IR thermometers not only have poor accuracy, but you probably have an extreme emissivity mismatch. A lot of IR guns have a fixed emissivity or even if it is adjustable a casual user doesn't understand what it does. Your gun is probably set around e=0.95, while your polished SS portafilter basket might have an e=0.15. Long story short, you could have a combined uncertainty/error of 20 - 40F.
The ideal way to measure the group head water temperature is a Scace thermofilter. Since that is expensive for personal use, a reasonable alternative is a fast reading stem thermometer in an insulated (styrofoam) cup. You can read previous threads for details about this method. Or a thermocouple could be used to achieve better accuracy. The temperature should be in the range of 190 - 205F. But without a lot more detail about how you are using your IR gun, I wouldn't have a lot of confidence in your measurement.
