so at least the Bezzera design is quite different from any E61 HX machine
@Márcio: the PID controls the boiler pressure only; GHT is regulated by a on-off thermostat.
@Márcio: I lowered my brewing pressure from 13 bar to 10 bar against a blind filter...can this affect HX flow?
@Jim: I read the HX volume in the BZ07 is only about 70 cc. If so I would expect brewing water to cool down after flushing for say 10 seconds, e.g. 80-100 cc water...
how to get a cool double shot on this machine, e.g. 91-92 degrees? I could lower the PID setting quite a bit and hence boiler pressure, but in that case I expect brewing temperature to be too cool in the beginning of the shot...or by means of longer flushing, e.g. more than 100 cc?
are there more BZ07/10 users getting a 8 second flash boil at a common boiler pressure, e.g. 1,1-1,2 bar? I only read and hear people of none at all or only a small 2-3 sec. water dance...
I'm going to measure how long it takes for the GH to come back to idle temperature (84-88 degrees Celsius) after a shot...
