pdx wrote:On any Synesso you can pull shots simultaneously on multiple groups at once.
If there is only one pump on the Cyncra, would not the overall brew pressure drop a bit if more than one group is engaged at once? Not familiar with Synesso machines.
I have experienced approximately 1 bar of pressure drop when engaging both groups at once on a Faema, and often wonder what would be the best way to eradicate that problem. Perhaps it is just not enough line pressure or flow rate?
On Synesso's website it says:
It features individual pumps and motors for each brew group, enabling baristas to preinfuse on one group while brewing on the other, set different pump pressures for different coffees, and allows for pressure profiling.
Does not make any reference about brewing simultaneously being an advantage. Which started me wondering about it all and why, if it has a pump and motor for each group, that would not be an advantage.
