I just moved in to a new house, and have the ability to plumb in my Reneka Viva 1. The drain is pretty straightforward, but I have questions about the supply line.
First question: It seems our city water is quite soft. The city report and prior experience point to not needing a softener. I was thinking about a single cartridge filter like those used for refrigerator supply lines. This seems easy enough to change if I want to upgrade it. Enough?
Second question: The Reneka Viva has a rotary pump, which auto-fills the boiler and pressurizes the brewhead path. I assume, because you can set the pump pressure, that this pump is regulated-- that is, the output pressure is (largely) independent of supply pressure. Is this true? And if so, do I need a regulator or pressure reducer on the supply line?
