novyan wrote:(Something to do with above and below 1.2bar-page 9 brewtus compendium?). Any one knows how to get around this? Will it work by reversing the connection between above and below 1.2 bar?? maybe an alex duetto schematic will help.
novyan,
From the diagram in the compendium, it looks like a SPDT switch would give you what you want. If your Brewtus matches this:
1. Disconnect the white wire (left side of PStat in diagram) and connect it to the COM terminal of the SPDT switch.
2. Connect one output terminal of the switch to the PStat connection that you just removed the white wire from (this will be the normal operating mode).
3. Connect the other output terminal of the switch to terminal 9 of the Temp Control box (this will effectively bypass the PStat, disable the steam function and allow uninterupted brew boiler control).
EDIT: You could alternatively tie this into the connection point labeled 'Above 1.2Bar' on the PStat.
Before doing any of this, verify your Brewtus matches the diagram form the compendium. And of course double check everything before powering back up!
George
