by CyclingCraig on Tue Sep 25, 2007 8:22 am
My Anita has/had that same noise. I adjusted the brew pressure back up to what it came from Chris Coffee. Set it to about 10 Bar on the Gauge on the front panel, which equates to about 9 Bar at the puck (According to my home build PF Gauge (see above post)). And my noise got MUCH better, only a twinge here or there, but MUCH better.
I am pretty sure the noise can't be bad, it is just a harmonic caused by water passing by the valve when bleeding off brew pressure?
Craig
