Stove-top bike-pump modification
Hi all,
For picture/video, check out:
I'm new to the homemade espresso world, but after learning to enjoy really good espresso made by others, I realized how dissatisfied I was with my cheap stove-top maker. I did some research and found the ideal temperatures and pressures for espresso, and realized that the stove-top maker was failing miserably on both those fronts (way too hot, far too little pressure).
So, first I got rid of the stove part and attached my own pressure source (a Coke bottle with a bike-pump hookup). Now I can precisely control the temperature & pressure to the degree/psi. All I can say is that it makes an incredible cup of espresso.
Cheers!
Taylor
Cheers!
Taylor
..I think you are pushing your luck if you are putting 7 bar pressure into that coke bottle !
- TomC
I think you should be commended for your ingenuity! Especially if it makes a beverage you enjoy. I just hope you're allowing your home roasts to rest before using them.
I was worried about that initially, but all the sources I could find indicate that Coca-Cola representatives say all their bottles are rated to at least 150 psi (a little more than 10 bar) - an industry standard. There is also evidence that the smaller bottles can hold higher pressure still with some sources saying up to 200+ psi.
Thanks for your concern though!
As an "industry " technical guy i can tell you the pressure requirement for those bottles is 6 bar (minimum).
They will hold beyond that , but remember that is for a fresh made , unused, undamaged, bottle.
just be careful, when they let go at that pressure, it can do damage !
- Randy G.
Why not use a PID-controlled small, portable electric air pump?
Seriously, trade out the coke bottle for a paintball gun bottle.
Besides your homemade bomb Coke bottle that was already commented on, that is a cool setup!! Cheap and ingenious!
“The powers of a man's mind are proportionate to the quantity of coffee he drinks” - James McKintosh
Great stuff, love it!
Could you post the exact parts you used, besides the bialetti and coke can?
Moka pots aren't designed to see 9-10 bar.
Surely, once fatigue sets in you WILL blow that plastic bottle, but I would also be cautious with that moka pot.
You are pressurizing it through the pressure release valve....
Surely that should raise a few yellow or red flags.
