Hi... I am new to the site and this is my first post. Thank you in advance for any help.
I just bought a new Alex Duetto II and suddenly after steaming milk I tried to close the steam. The knob turned normally but the flow kept going. I had to turn the machine off.
I called customer service and they told me to remove the cover of the knob, the c-clip and remove the knob to look for a loose piece. I don't see anything that is loose. I even remove the valve and don't see anything wrong. I tried to reassemble, but know I can't put the c-clip back on. It looks distorted. Should I buy a new c-clip? I am still not sure this will fix the flow issue, since the c-clip was fine before I removed it.
Any ideas on what could be the problem with the knob not closing the steam flow.
Thanks again!!!
