Hello,
For a long time now I'm having serious problems with my Cimbali Dosatron M30. I'm not a technical expert, so I'm probably not using the right terminology, but I'll try to explain it below:
On top of the water/steam tank there is a valve that screws into the tank. On the machine there is also a timer that turns the machine into 'sleep'-mode at night. When in the mornings the tanks warms up again, very regularly, the steam escapes from the valve with loud bangs. It looks like the steam escapes from the sides of the valve (so basically through the threads of tanks and the valve).
When I turn the machine off the explosion stop and they start again when I turn it on again. Usually after about ten times turning it on and off for some reason the steam explosion stop to occur and the tank stays on temperature.
But then the next morning the whole circus starts again... I could turn of the timer so the machine stays on 24/7, but it's a pretty old machine and I'm afraid of short-circuits and fires in my hotel...
I have tried to use different kinds of rings and gaskets to seal the valve better into the tank, but this doesn't seem to work.
Does anybody have a solution for this problem?
Thanks!
Eric Pantekoek
