by cannonfodder on Fri Sep 03, 2010 10:50 am
There is a rubber plug on the end of the valve stem that seats against the inlet tube from the boiler. There is a ring around the tube (like a donut) that the plug seals against. They get hard and compress over time and the rubber plug no longer seals good. All it needs is a new rubber insert, but they are not a replaceable part. You have to replace the entire valve stem. I think they are $25 ish but it has been many years since i looked. If you want to cheat a bit. You can drill out the rubber insert in the valve stem, then cut a new gasket from some gasket material the same size. Problem is getting it back into the hole. The end of the valve flairs in to hold the gasket in place. You have to cut it big so it will stay put. I did it once. I had to cut a small taper on the back of the gasket to fit inside the roll crimp on the end of the valve stem. Put some food safe lube on the gasket then push of all your worth to get it to pop into the cup. But it worked, cost me all of a couple dollars and I did not have to wait weeks for a replacement stem to show up. FYI, I had a millennium but the Tea is the exact same innards.
