For quite some time now (2 months or so) I cannot help but feel that steam power on my Oscar has diminished continuously. It is one of these phenomena where you cannot quite put your finger on exactly when or how it started. But one day you realize something's afoot and has been for some time. Actually it was not the change in steam power I noticed, but that I had inadvertently been turning open the knob some more than I used to. The Oscar steam knob has a ridge which always used to be horizontal when I was steaming along, about a quarter turn from full throttle. Over these past weeks I have been nearing vertical, and thus full throttle. If things go on like this there is no more turning to do and I'll end up with a serious no-foam problem
At first I thought it might be a consequence of an exchanged pressurestat in October. My Ceme broke on holiday (in Italy
)and was replaced by a Mater (at absurd cost, but unfortunately I had no tools with me). I thought maybe the Mater has a different deadband and somehow this would contribute to a change in steam level. That would explain a one off change in steam power if any, but it continued to go down.
Next thought was scale in the steam path. My strictly non-scientific, non-techie mind tells me that "impeded" steam is not necessarily diminished (the contrary even), but then who am I to know. So, off came the steam tubing, valve etc. starting from the boiler. It looked absolutely clean to me, but went into a citric acid bath nonetheless. Alas, to no avail.
Fill probe maybe? Maybe those Italian mechanics tampered with it? Off goes the cover. The probe is all the way in, that in my book should provide max steam. But - trial 'n' error - I drew it out a centimetre or so. No change.
Mmm ...
I haven't got any more ideas to be honest. Maybe you guys have something up your sleeve. The whole thing doesn't make any sense to me. The Oscar as you may be aware has no boiler pressure manometer, so I have to rely on the styrofoam cup temp measurement. Temp is quite the same as ever, which, given identical fill probe seating and descaled steam path, should mean same steam power. It doesn't though.
Your input is very much appreciated by
Sheygetz
