Steam instead of hot water out of water tap
I have just started using a rebuilt Linea 1 group, but instead of hot water I get mostly steam out of the hot water spout. It starts with a bit of hot water and then deteriorates. I did reinsert the hot water syphon tube into the boiler when I refitted it. The only difference now is that I am feeding through a steam valve assembly. (Which seems to be standard for a 1 group Linea) I did swap the steam to the left hand side of the boiler, so the outlet is now close to the element, because I was tired of burning my hand on the steam wand when I turned the machine off. Could this be the problem?
ideas to check:
- leak at top of syphon tube, allowing steam to enter
syphon tube not long enough (and after a little of water is drawn off, syphon perhaps exposed)
cheers
Paul
LMWDP #084
Paul
LMWDP #084
- eastpresso
Could also point to water level in steam boiler too low (autofill probe too long) ?Paul wrote:ideas to check:
- syphon tube not long enough (and after a little of water is drawn off, syphon perhaps exposed)
Hi Paul, you were spot on; I forgot that the diameter of the boiler had changed so I need to lengthen the syphon. D'oh! All working well now with an acceptable mix of water/steam coming out.
