Steam boiler in my Vivaldi doesn't refill. There are no special symptoms like alarm lights or anything, it just doesn't intake water. Some week prior to this happening it started taking the water in strange way, repeatedly 3 times in a row refilling, or making longer breaks before refilling.
Here are more details as typed on the post at Vivaldi forum:
First time something similar occurred when I emptied the boiler after returning home from travel - after I did so the boiler didn't refill; but, after unplugging the machine from power and plugging back, everything came back to normal. (it was some year o even more ago)
Then it happened again some month ago by itself - after drawing two glasses of hot water the boiler didn't refill - and the solution of unplugging from power again worked. But I noticed the boiler was refilling in smaller quantities, repeating the refilling one after another - like three times in a row.
Then again today it just didn't refill after I had a glass of hot water taken and didn't come back to normal. In fact I emptied it almost completely - opened the steam valve and let steam out; previously steam was coming out the hot water tap.
Now I drained the steam boiler opening the valve at the bottom and letting all water out. Yet there is still no change - it doesn't refill and tries to heat up empty... which I don't let it do.
I am running mineralised RO water all the time so I would be surprised to see scale on the sensor or anything and then, why would the rebooting help the other two times?
Any help or ideas very much appreciated! Thank you.
PS: Crossposted from Vivaldi cafe for the sake of getting more help.
