HB wrote:To check the obvious first, have you tried opening the steam valve to release false pressure?
Bluecold wrote:I don't think it is false pressure since false pressure is pressure too and the steam wand would just give slightly warm air.
Also, the light is on which means the element is on.
Have you tried measuring continuity? Elements rarely go bad. Probably a bad connection, or some safety gizmo failed.
