by Sketcher on Fri Mar 05, 2010 12:16 pm
Hi Everyone,
I know, my machine isn't great but university wasn't cheap for either my wife or I but I do aspire to better things. Anyway, we've had the Barista Dec 2005 when it was purchased new. However, we went through a period (1 year) when it was stored away (heated) during some massive renovations. I have to say though, it's been good to us. Anyway, We recently tried to get it going again and basically when it turns on it heats well, primes well, steams as well as ever (I see you at the back there snickering at my tiny boiler) but doesn't brew well at all. When priming, the pump kicks in, as it does during brewing. I was able to compare the brewing to another identical machine though. With the portafilter off, we get a gentle sprinkling of hot water through the screen. With it on, we get about a drip of coffee every second and there's nothing resembling a puck in the portafilter at the end, just some swampy goop. I first tried to clean the machine by filling the reservoir with a light mix of lemon juice and water and running it repeatedly and retried it a few times on successive days (dare I mention I never descaled it in the first 3 years of ownership?) That didn't help, so I decided to take it apart. After mild difficultly, I was able to get at the tank (if the tiny excuse deserves the name), open it and found a good half a cup of limescale particles sitting in the bottom. My lemon juice job had loosened it all from the heater and boiler body but it all rested at the base of the tank. Anyway, I got rid of it all, thinking that'd be it for my problems and I'd be off to the races. Nope, still no pressure. The machine I compared it to has some nice jets of water pumping through the screen during brewing (no portafilter) while mine gives me a really gentle sprinkiling (as if through a watering can). One other thing, while brewing, the Ulka pump kicks in (through it's charateristically loud sound) but later goes very quiet, as if it's at maximum discharge pressure.
Because my machine primes just fine (nice powerful stream through the wand), and the steam is good, I think my problem may lie around the main screen. There are two means of mechanical pressure control on the machine from what I can see. First, there is a spring with a plastic ball on top which screws into the bottom of the boiler body. With adequate pressure in the boiler, the spring is overcome and lets hot, high pressure water into the screen area and into the portafilter below. Also, there is the spring in the base of the portafilter, which allows a small hole in it's base to open, allowing coffee to flow into the cups.
Either my pump doesn't produce enough pressure for some reason (but I don't think this is it because it works well on priming and makes all the right noises) or I still have a blockage but I'm hard-pressed to see how since I tore the machine down and rebuild it. All the parts are in excellent condition, save the portafilter which I'm going to clean next, but I think my issue may be exclusive of it because with no portafilter my discharge water is very low pressured. Any suggestions from others? I know it's a good excuse for a new machine but for the next couple of months I need a machine to hold me over until I can get into something more serious (and need time to appease the wife too).
