First I'll preface by again saying my garbage can wrapped rotary direct plumbed Bricoletta's HX and/or E61 group tuning may be different (run hotter) than current production Bricolettas. Mine was the last from a lot of 30 Chris imported quite some time ago then he decided not to carry but rather developed the Quick Mill line. I know mine came with the old lighter vacuum breaker valve that had a tendancy to give intermittent false boiler pressure from cold heat up which I replaced after about a month. Unknown what other production changes were made to more current models based on user feedback to Fiorenzato.
edwa wrote:miKe mcKoffee wrote:These two flushes would be either 6 counts beyond flash and count for 201f (meaning 5 counts beyond flash for 201f plus 6 counts for 11 counts beyond end of flash total) OR to Eric's digital thermometer actual reading of 201f.
Huh?
Here's what I did trying to follow your lead:
LONG idle ~ 8hrs,
Flush and add a 6 count after the "water dance" ends and then stop flush,
After approx 35 seconds have Pf built and begin 2nd Flush,
Add a 5 count once the "water dance" ends and then stop flush.
Immediately lock in pf and pull shot.
If this attempt isn't what you meant, do me a favor and cut and paste where the procedure should differ.
For target shot temp of 201f of previous example not quite.
Initial flush from idle is count to desired target temp
plus 6 count additional. Since flush-n-go technique during shot production for attaining ~201f shot temp is 5 count beyond flash, initial flush is 5 count
plus additional 6 count for 11 count total. Flushing via Eric's digital thermometer adapter I now flush to Eric's actual reading of 201f for initial flush.
No. During cooling/stabilizing flush #1 I start grind. (I grind into SS cannister). After grind complete I do a
second cooling/stabilizing flush exactly like the first. The first two flushes are with empty PF in the group. Now I remove PF, wipe dry, build shot and gently set PF on the counter. This is were the 35sec minimum comes into play. Next I do the flush
(yes a third flush for from idle shot!) for the flush-n-go shot. For 201f shot target this is 5 count beyond end of flash or add +6 to target temp Eric's adapter digital thermometer reading, for 201f shot temp this is ending flush just as reading comes down to 207f. Immediately lock in built PF and pull shot.
All my shots get a post shot ~3oz total volume empty group flush-w/blank wiggle flush-empty grup flush. Now minimum 35 second pause comes into play again before next flush for shot lock and pull. Same as third flush from idle above, flush temp descending +6 reading Eric's lock and pull. (or count from end of flash of course)
Recap:For 201f target shot temp from idle (idle time doesn't seem to matter whether 5 minute or 5 hours)
1) With empty PF in group flush to 11 counts past end of flash/Eric's digital thermometer reading 201f. (my count pace slightly faster than one per second) While flush running grind da beans for shot.
2) 2nd flush to 11 counts past end of flash/Eric's digital thermometer reading 201f. Remove PF, wipe dry, build shot.
3) After minimum 35 seconds have elapsed now flush for shot: Flush to 5 counts past end of flash/207f Eric's digital thermometer reading. Immediately lock and pull shot (< 5 seconds from stopping flush to starting pull).
4) Post shot ~3oz total volume flush-w/blank wiggle flush/flush.
5) Build next shot in series repeating from #3 with the minimum 35 seconds being from end of post shot flush. I grind for the next shot during the previous shot so it's ready to build PF as soon as post shot flush completed.
To maybe help clarify here's for 200f target shot temp from idle:
1) With empty PF in group flush to 12 counts past end of flash/Eric's digital thermometer reading 200f. (my count pace slightly faster than one per second) While flush running grind da beans for shot.
2) 2nd flush to 12 counts past end of flash/Eric's digital thermometer reading 200f. Remove PF, wipe dry, build shot.
3) After minimum 35 seconds have elapsed now flush for shot: Flush to 6 counts past end of flash/206f Eric's digital thermometer reading. Immediately lock and pull shot (< 5 seconds from stopping flush to starting pull).
Interestingly enough the temp at the end of the second flush was 207 - and change, on the readout off of Eric's adapter. Locked in the Pf and pushed down the lever, by that time the temp had decreased to 205.3. The shot, however, was far from stable as the temp continued to plummet and reached the low 195's on Eric's adapter by the end of a 20 second count.
I see temp via Eric's initially at start of shot ~1 to 2f higher than Thermofilter will peak with <1f variance between the two by the time Thermofilter peaks until end of shot. Typically 2 to 2.5f intra-shot total temp drop via Thermofilter equalling Eric's reading down around to 198f end of shot for 200f target shot.
My Volante doesn't have your boiler insulation mod.
Based on Thermofilter temp testing prior to insulating I saw virtually no change in my Bricolettas intershot and intrashot behavior post insulating. I did of course see reduced heater on time while idle.
But, it needs a longer time between 1st and second flush. I found the 6 count past 1st flash yielded around 6 oz.s maybe less and the 5 count past 2nd flash a little less than 4oz. This is very close to my method but the additional time to grind, remove & dry off the PF,dose, WDT, and tamp BEFORE starting the 2nd flush helps my Volante rebound. Then I do what is very close to a 5 count past end of flash which usually is around 210 to 211 on the readout and then I pause for the few seconds as the temp gently goes down to around 207-206f - lock in the PF and then pull at 205.1 ish. The temp then usually drops to the low 204's and ends after a 25 second pull with a readout from the high 201's to low 203's. It varies with the length of the pull but generally the best I can get is around a 2 degree variance.
Thanks,
Ed
My needed flushes seem larger volume wise than some have reported. Inital flush current procedure usually around 9 to 10oz depending on target shot temp, 2nd cooling/stabilizing flush about an oz less. Then my flush for flush-n-go 4oz or so. But these are of course not to flush by volume but rather by temps so will vary depending on idle/pause during build times etc. When I was attempting a single cooling flush took more like around 14oz or so and wasn't as predicatable as using two initial cooling/stabilizing flushes..
