jbell wrote:sounds like your brew pressure is definitely too high... im not certain if you can adjust the opv on the Ascaso. I'd reduce the tamp or coarsen the grind.
The
FAQs and Favorites notes several discussions on OPVs under
Vibratory pumps; in particular I draw readers' attention to
I still don't get it: Why adjust the OPV, specifically the comments below:
another_jim wrote:You can adjust your grind and tamp to pull a 9 to 10 bar double; but for singles and ristrettos, you can't. The Italian spec for vibe pumps is to set it to 11 bar on a blind filter. If you can see the pressure during a shot, adjust it while pulling a single or ristretto, so you get 9 to 10 bar.
HB wrote:If you do some calculations to determine the flow rate / pressure intersection for the vibe pump, you'll find that it conveniently works out to around 9 bar -- if you're pulling doubles. As Jim notes, an OPV acts as a "safe release" for ristrettos where the pressure would otherwise rise to 10+ bar given the slower flow.
For even more details, see
purpose of adjusting OPV?
For less experienced baristas, lowering the brew pressure increases the margin of error. While that's not a bad short-term solution, the better solution is correcting the technique errors through practice and extraction diagnosis via a bottomless portafilter.
As for the tamp, I put it near the bottom rung of probable causes. Even newbie baristas master the basics of tamping in short order; keep it consistent, level, and move on. The only tamping technique I've found makes a significant difference is
nutating, though I hesitate to recommend it to new baristas since it will make a bad pour disastrously worse if done incorrectly.
