zin1953 wrote:I'm not arguing, Chris. I think both types of machines are quite capable of producing excellent shots . . .
What Jason said. In fact, that was one of the main points of this thread.
akallio wrote:Out of curiosity: if you would set out to "ambush" Izzo Alex Duetto (with steam boiler on), what would be the sequence that you'd try first? Duetto is a thermosyphon DB, but the design of the thermosyphon loop is better than in some other E61 DB's AFAIK. I have been playing around with my Duetto now and measuring thermal stability in different conditions would be one interesting thing to do.
gscace wrote:
I read lots of comments about engineer types trying to measure this and analyze that, vs tasting coffee.
gscace wrote:Now some have argued that the test isn't relevant for home use, but I disagree. The idea of the test isn't to talk trash about machines, but to learn how the machine behaves and what can be done to optimize the behavior.
gscace wrote:I read lots of comments about engineer types trying to measure this and analyze that, vs tasting coffee.
gscace wrote:I think that the best reasonable test would be to run the WBC test series and look at how the machine behaves from very intermittent duty to through full-on, elbows-flyin, coffee-spewing frenzy... Now some have argued that the test isn't relevant for home use, but I disagree.
malachi wrote:Out of curiosity... how many of you are NOT arguing that your own personal machine type (DB, HX) is superior?
gscace wrote:Examples of such cobbling is the use of thermosyphon groups in double boiler machines. There really is no good reason for this. The thermosyphon group works properly when there is a large temperature difference between the boiler and the group. The double boiler idea is that the brew water should be very close to brewing temperature
danetrainer wrote:Certainly correct me if I'm wrong...but my Brewtus III DB has the thermosyphon supplying the water to the brew boiler. To me this is an excellent engineering concept to minimize the "shock" of cold plumbed-in water entering the brew boiler and the PID going into a frenzy trying to keep up with a series of shots.
gscace wrote:An example of this might be a hypothetical double boiler machine with an e-61 group that features brew boiler feedwater preheating. We may find that at very high duty cycles the brewing temperature climbs enough so that the quality of the shots is affected, while the repeatability at lower brewing frequencies is very good. We'll then have to decide which is more important for our style of use, and if the machine is suitable. For the example given, if we value the ability to make walkup shots with minimal fuss, and don't often brew many shots in a row, the deficiency of the machine has little consequence. But if we intend to use the machine for parties and catering, we'll know that the machine has limitations
