Kristi wrote:No tang. Tastes like boiled water with maybe the slightest hint of rubber.
However, I noticed that the OPV tube had white on the inside where it was in the reservoir water. So I disconnected the OPV tube and blew it out, then breathed in a tad through it and got a horrible smell/taste. So I left the OPV tube off and now have a little drain on the drip tray. Wonder what that's all about. (The stock unit does not have an OPV tube.)
In the meantime I pulled 90% of the insulation off and am now warming it up again and will pull another test in a bit.
Well, plain water tastes better now. (I replaced all the water in the reservoir while I had it apart) The result of not recycling the OPV water?
Shot tastes very good now. Temp rises maybe .5 deg F during shot. Interesting to me, though, is that after the pull, the head temp (tc on top of head) drops from roughly 203 to 187F. Have no idea why it does that, and seems to take a long time to recover (like 15 minutes). Pstat seems to be functioning correctly as pressure stays between 1.15 and 1.3 (relative, as this gauge was broken. Repaired by yours truly but only functions in relative sense - not calibrated. Boiler temp is 240. May be that I should simply raise pstat.(?) New double gauge arrives tomorrow but I won't know until I get it whether I have the correct fittings to install it.)
So if inside of box is hotter, it works better. Or perhaps more accurately, it works as designed...
However, if this is a result of heating up water in the reservoir, how would/could this function on a plumbed machine?
