Slight "squeak" in brewing lever when turning off E61
Postby gegtik on Fri Oct 14, 2011 10:03 am
Hi all,
Last year I purchased a used Vibiemme Domobar (the plain-jane pump-driven SBDU variety) and have been pulling terrific espresso from it. I don't think the previous user backflushed with detergent at all.
After a few detergent backflushes, I noticed that the lever would squeak when I push it to the off position until I pulled a shot or two. After some research I found this:
http://coffeetime.wikidot.com/e61-lubrication
After ordering and receiving the espresso lube, I took apart the lever section and lubed the cam head as indicated, and it's improved, but I can still feel that squeak. The cam head is a little rough from metal-on-metal friction; I can't tell if the pins have been worn down or not. (this is the head I'm talking about -- http://www.coffeehit.co.uk/lever-rod/p281 )
Should I attempt to polish the cam head? Or just buy new parts? If I buy new pins I assume I'll have to completely disassemble the whole grouphead.
Thanks for any advice!
gegtik
Postby cannonfodder on Fri Oct 14, 2011 10:40 am
That is normal. Squeaking after a chemical cleaning is normal. After a couple of shots the coffee oils will lubricate the cam and follower and the squeak will go away. No need to polish or do any other voodoo. Just pull some shots. If the group starts leaking, then you may need to replace a couple parts but until then, enjoy the espresso.
cannonfodder
Postby erics on Fri Oct 14, 2011 3:09 pm
The top surface of the two 6 mm "pins" that come into contact with the cam is uniformly beveled slightly (indicated in black). If this bevel is worn out (can be a little subjective), time to replace.
Use Vibiemme OEM parts as they differ slightly from standard E-61 parts. Replacing these two parts takes all of 5 minutes max. Another source of squeaks is the spring and cam surface that contacts the bushing/washers in the lever arm assembly. This would take about 10 minutes as it is all much simpler than what/how it may appear.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby Randy G. on Fri Oct 14, 2011 4:14 pm
..and illustrated, full step-by-step instructions for lubing as well as complete overhaul of the E-61 are on my website in the "How-To" section....
Espresso! My Espresso!
Randy G.
Postby spiffdude on Fri Oct 14, 2011 7:00 pm
Did you lube the shaft as well? In my case, the squeak was coming from lack of lubrication of the shaft, not on the cam or pins per say.
Damn this forum, I've had too m..muh...mah..mmmm..much caffeine!
spiffdude
Postby gegtik on Sat Oct 15, 2011 1:41 pm
I did lube the shaft as well; the squeak only occurs at the last tiny bit of the lever throw when I am shutting off the flow from the pump.
Thanks for the pointers Randy -- and eric, thanks for letting me know that the VBM parts are slightly different from stock E61 - I had been considering getting Faema replacement parts under the assumption that all E61 groupheads were identical
gegtik
Postby spiffdude on Mon Oct 17, 2011 5:50 pm
This has been mentioned in other posts as well but did you check that your pump switch is not causing the noise? The cam formed by the lever body actuates a switch that can sometimes sqeak as it's a metal pin sliding on a metal body...
Just trying to cover the bases, sorry if this seems too obvious.
spiffdude
Postby Randy G. on Mon Oct 17, 2011 6:12 pm
gegtik wrote:I did lube the shaft as well; the squeak only occurs at the last tiny bit of the lever throw when I am shutting off the flow from the pump.
If the squeak is right at the last 3 to 5 degrees of movement (that is, right at the end of travel when lowering the lever), the squeak is likely between the cam and the exhaust valve, or it is the exhaust valve's spring. This is assuming that the shaft is not the problem. The next related question, did you put a dab of grease on the END of the shaft at the cam-end of it, where the short stub of the lever's shaft fits into the machined hole inside the group?
Randy G.
Return to Espresso Machines
