Jim Schulman wrote:In reverse osmosis, some water is forced through a membrane impermiable to minerals which are washed away by the proportion of water not passing the membrane. RO should produce virtually pure water (below 1 mg/l total solids); however, mineral removal is compromised when the amount of waste water is reduced. For instance, supermarket RO vendomats in very hard water areas may put out as much as 50 mg/l hardness and alkalinity levels. Home reverse osmosis systems are generally self-cleaning, but need to be installed and set up by specialists. They are more expensive to buy and operate than ion exchange softeners (see below).
My emphasis. From The Insanely Long Water FAQ.Jim has me a little concerned about my idea of buying RO water from the supermarket in Los Alamos. I certainly am not sure I would trust them to set the product:waste ratio properly, especially in light of the price of water in our desert. Here in Norman, RO water at Wal-Mart is $0.33/gallon. I can imagine that the price in Los Alamos will be comparable, if not significantly higher. In light of that, I have on one hand serious concerns about the quality of water from supermarket RO water, and it will also be expensive. I can imagine that, considering I want to set this up for drinking water as well as Vetrano, that I will be using 3-5 gallons every day. Maybe not quite that much, but I expect my initial guess of 10 gallons per week was quite low. Regardless, that gets expensive. Even at an optimistic $0.33/gal and 3 gal/day, that will be $365. More realistic estimations are much pricier.
It begins to look as though, even if I had to replace all filters (a given)
AND my membrane every year, that it would quite quickly become cost-effective to go with an under-sink RO unit.
I talked to a number of different water treatment folks today. The first guy was from a
local place in Santa Fe, NM. He was optimistic about RO taking out silica, though he didn't seem like he was very knowledgeable about it. He took my digits and promised to consult his literature to see if he could get more details and get back to me. His prices, including installation, were pretty good, although I forgot to ask him about any form of remineralization for coffee. I suppose I can always add a calcite filter myself (I have the housings on hand from my current setup).
The second guy, also a
local from Santa Fe, was much more pessimistic about getting Silica out. He claimed that silica removal right out of an RO unit would be pretty poor--on the order of 50%. I found this a little startling. Still, it seems like the complexity of silica's presence in water would allow there to be such ridiculous discrepancies in what people say--from what little I have gleaned from my own survey of the literature, it seems like even the basic distinction between dissolved silica and colloidal silica is not really adequate to grasp the different types of interaction it will have with water.
Anyway, this guy seemed pretty knowledgeable about the issue, especially from a local perspective. He said that Los Alamos' wells have between 50-70 mg/l silica. He told me that he was working with an engineer in Arizona to develop a practical solution to silica removal prior to RO processing. He gave me his digits (I'll give it to you if you are curious--PM me), and I gave him a call. Sam was a quite personable guy, and he said that he was looking at some specialized media that would remove colloidal silica, with the catch being that the media would need to be replaced about every 3 months (a filter replacement). He said that the price of these would depend on the price he himself gets for the media in bulk, but he anticipated in the range of $10-15. It seems that, regardless of what option I go with for RO, I can always put one of these upstream of the system, if they work out. They fit in a standard 10" filter housing.
Finally, I called
SpectraPure of Tucson, AZ. They were pretty friendly, although the saleswoman was a little confused by what I said. I was inquiring about their "SilicaBuster" deionization filter, and their RO/DI solutions in general. I was curious if I could get an RO setup that used RO, then deionization, and then remineralization (basically, their
"Coffee Lovers' RO unit", but with
this stuck in between the RO and re-mineralization filters). In pretty short order she connected me with an engineer who was, well, an engineer (
and I don't mean that in no nice way!
). He told me that the RO unit they sell generally will get rid of 98% or more of TDS, and with my levels of Silica, it may drop to 94% silica removal, but that it would still be less than 1 mg/l of silica. He said that they didn't offer any way to put deionization in between the RO and re-mineralization filters with the current products that they sell, and went on to say that DI is quite specialized and specific to aquarium solutions--that it would be vastly overkill for what I want. He told me that he thought I would be quite happy with the Coffee Lovers' system's performance for my espresso.
My slight dislike of his tone aside, I tend to believe him. And while it is expensive, the
"Coffee Lovers' System" seems like it might be ideal--it would simplify the whole process of tuning the output water for a sufficient hardness to make decent espresso. June's comment in a
recent H-B thread certainly recommends them after her time with the unit running on well water with whopping 500 ppm TDS (!). I feel like her numbers ought to reflect what I can expect, in light of the fact that I will have much lower TDS but large amounts of Silica.
My thinking at this point is to splurge on the up-front cost and get the SpectraPure RO unit. If I need to down the road, I can give Sam's little 10" filter a shot as well, upstream of the unit. Any comments or further suggestions are welcome, especially if you see any gaping holes in my logic. I will keep you all posted as things pan out. I'm still planning on getting a Silica test set to make sure this is working.
Like a coworker of mine told me recently in response to my silica worries, "Man, being a geek is expensive." I sarcastically responded that it was still a lot cheaper than his Volvo...
