Abe Carmeli wrote: I don't know enough about your thermometer or T/C. You need a very accurate one and a 36 gage type T or K T/C. With the basket in the P/F, snake the T/C over the basket rim and have it touch the basket bottom around the center...
After 40 minutes idle time, run a flush with your T/C in the P/F to measure flush temperature. It should read as follows:
~210-211 f for 4 oz, and then gradually go down to 201f around 8 oz.
Again, your pressure stat should be @ 1.1 bars.
My gauge isn't anything fancy, but it does read boiling water at 210 (1,400 ft)
Abe Carmeli wrote:Now if you want to test Brew temperature, it must be done during a real shot, that is with coffee in the P/F. use the "Snake the T/C over the P/F rim" method I described above.
I did these this morning, and still my max temp was around 175-180'. That was with the machine running around 1.35 - 1.5 bars, just to exaggerate the effect.
If things are running correctly, and my machine is set too high, shouldn't there be steam blowing out the head at the same time if it's that hot? The stream is smooth and there is no steam.
Dan - shots are on the weak side. They look watery to me and the crema is light. I have a comparison from the LM to my giotto for the black cat and the crema on the LM was reddish brown and mine is pale beige.
