by aindfan on Mon Jun 27, 2011 9:52 pm
I think I saw a post on here that said something like:
- Fill until probe is covered
- Keep filling for n seconds
- If probe uncovered, wait... um... a bit?
- Goto* first line
Now... even though the relay is busted, I can still use the node that's trying to power the relay. I would need to drop the voltage (safely, not just with a resistor divider), pass it to the arduino to indicate that the relay is being turned on by the gicar, and use that to trigger an SSR.
Ok, you're right, I should just replace the relay.
EDIT: Wait a minute!!! Just because I'm replacing the relay doesn't mean I have to replace the relay! I can use the Gicar relay trigger node to enable my SSR, which is rated to 3-32VDC control input. Sound ok?
*Yes, I know, goto statements make me sick with all of that OOP indoctrination, and I should have implemented those four lines in an object-oriented way.
Dan Fainstein
LMWDP #203
PSA: Have you descaled lately?
