AndyS wrote:If one considers a gentle preinfusion to be "pressure profiling," it is not hard to prove an effect on the extraction.
With a gentle preinfusion (say, 15 sec before 1st drop appears) as opposed to a minimal preinfusion (say, 5 sec before 1st drop appears), one can grind slightly finer and still achieve a comparable flow rate. The finer grind/preinfusion technique results in a slightly higher extraction yield (by maybe 0.5%) which is measurable via refractometer. I'm not sure if a 0.5% difference can be reliably tasted, but given the right coffee and the right tasters, it may be possible.
That's an interesting idea, and something I could easily do manually with my paddle machine. It's sufficiently interesting that when I have some more time I think I'll play around with it. I do (occasionally) go back to line pressure at the end of the shot, some of the time to "salvage" a briskly flowing shot, and sometimes because it looks cool. I have no evidence that this makes any difference whatsoever in shot quality.
ken
